Year 2025 Goal: €50.00
PayPal Fees: €10.74
Net Balance: €144.26
Above Goal: €94.26
289%
  • Total des membres: 2754
  • Dernier: Jasmp25
  • Total des messages: 220902
  • Total des sujets: 9262
  • En ligne aujourd'hui: 184
Invités: 183
Total: 183
Auteur Sujet: [Roulements AV/AR] Schema  (Lu 5131 fois)
  • Q.I.: 34
« le: lun. 25 août 2014, 18:34:06 pm »
  • Avant
    « Modifié: lun. 25 août 2014, 18:38:22 pm par bobinesimple Alias Magimojo »
    • Q.I.: 34
    Re : [Roulements AV/AR] Schema
    « Réponse #1 le: lun. 25 août 2014, 18:39:19 pm »
  • Arrière
    • Q.I.: 34
    « Réponse #2 le: lun. 25 août 2014, 18:40:02 pm »
  • TourFL si tu me lis  #g3
    Connection Problems
    Sorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later.
    Warning: Cannot modify header information - headers already sent by (output started at /home/www/f0c672b840553ce2a90bc12359a844d6/web/Sources/Errors.php:420) in /home/www/f0c672b840553ce2a90bc12359a844d6/web/Sources/Errors.php on line 351
    Warning: Cannot modify header information - headers already sent by (output started at /home/www/f0c672b840553ce2a90bc12359a844d6/web/Sources/Errors.php:420) in /home/www/f0c672b840553ce2a90bc12359a844d6/web/Sources/Errors.php on line 352
    Warning: Cannot modify header information - headers already sent by (output started at /home/www/f0c672b840553ce2a90bc12359a844d6/web/Sources/Errors.php:420) in /home/www/f0c672b840553ce2a90bc12359a844d6/web/Sources/Errors.php on line 353
    Warning: Cannot modify header information - headers already sent by (output started at /home/www/f0c672b840553ce2a90bc12359a844d6/web/Sources/Errors.php:420) in /home/www/f0c672b840553ce2a90bc12359a844d6/web/Sources/Errors.php on line 356
    Warning: Cannot modify header information - headers already sent by (output started at /home/www/f0c672b840553ce2a90bc12359a844d6/web/Sources/Errors.php:420) in /home/www/f0c672b840553ce2a90bc12359a844d6/web/Sources/Errors.php on line 357
    Warning: Cannot modify header information - headers already sent by (output started at /home/www/f0c672b840553ce2a90bc12359a844d6/web/Sources/Errors.php:420) in /home/www/f0c672b840553ce2a90bc12359a844d6/web/Sources/Errors.php on line 358
    Connection Problems
    Hors ligne impala
    • Q.I.: 25
    « Réponse #3 le: lun. 25 août 2014, 19:25:02 pm »
  • Sympa  #B6, par contre je serais curieux de savoir ou tu a commander des roulements SKF, car ceux que j'ai commandé me paraissent assez limite niveau qualité.
    « Réponse #4 le: lun. 25 août 2014, 20:19:06 pm »
  • La vache, comment tu fais pour avoir tout ces erreurs (qui ne sont même pas loggué chez nous)  #f9
    On dirait que de temps en temps, il y a trop de trafic sur le serveur, mais ça n'arrive qu'a toi  #i6
    • Q.I.: 34
    Re : Re : [Roulements AV/AR] Schema
    « Réponse #5 le: lun. 25 août 2014, 22:04:53 pm »
  • Sympa  #B6 , par contre je serais curieux de savoir ou tu a commander des roulements SKF, car ceux que j'ai commandé me paraissent assez limite niveau qualité.
    Achetés, il y a 1 ou 2 ans, c'est juste que j'ai retrouvé ces papiers récemment.
    Ca venait d'oscaro ou un truc du genre, c'était en promo à pas cher.
    La qualité semble top, sauf peut être les écrous à mater.
    Tu as la boite bleu qui va avec ? ils sont emballés dans un sachet normalement, ils sont marqués aussi SKF je suppose.
    Tu as acheté où ? j'ai du mal à croire qu'ils produisent plusieurs qualités
    Hors ligne impala
    • Q.I.: 25
    « Réponse #6 le: mar. 26 août 2014, 05:44:03 am »
  • ...je crois qu'il y a un malentendu  #g6
    Ceux que j'avais commandé chez un marchand habituelle de pièce de Fiat 500, il me semble que c'était chez FD Ricambi, était d'une marque que je ne connaissait pas et me paraissaient un peu light, et justement à choisir je préfèrerais commander des roulement de marque connue comme des SKF, vu que a terme je risque de changer mes roulements arrière, donc si je peu monter du SKF sa serait top au vue, justement, de la qualité reconnu de cette marque.  #b3
    • Q.I.: 34
    « Réponse #7 le: mar. 26 août 2014, 09:48:52 am »
  • je ne sais plus si c'est l'avant ou l'arrière, mais en fait le SKF chez bidulemoderneauto était moins cher que le polonais pas cher chez le marchand de 500, donc c'est vite vu.
    vu l'écart de prix (0 ou rikiki) et la merde que c'est à mettre, le choix est vite fait à mon avis...
    il y a aussi certains détaillants SKF (j'en ai à côté de chez moi)
    si tu veux les références, je peux retrouver
    « Modifié: mar. 26 août 2014, 09:50:39 am par bobinesimple Alias Magimojo »
    « Réponse #8 le: dim. 19 octobre 2014, 22:41:54 pm »
  • je profite de ce post sur les roulement si déjà quelqu'un a eu des problèmes de fuites avec le joint de roulement sur les tambours avant! car une fois j'ai changé le roulement a l'avant gauche et l'ancien joint mis métal mis caoutchouc avec un ressort dedans est remplacé par un tout caoutchouc avec son ressort....et la...de la graisse partout sur les mâchoires!  #j2 tu m'étonnes que j'avais un déséquilibre au CT! Je pensais avoir mis trop de graisse, donc je démonte je change les mâchoires, enlève de la graisse....et rebelote! et la comme j'ai changé aussi mon roulement avant droit l'autre jour, je profite sur le côté gauche de changer le joint et depuis ça freine encore moins et suis sur d'avoir des fuites des deux côtés! pas eu le temps de regarder.....
    d'autres ont eu des problèmes avec ces putains de joints a la con?
    • Q.I.: 34
    « Réponse #9 le: lun. 20 octobre 2014, 17:35:52 pm »
  • t'as encore acheté où tes roulements (et joints qui allaient avec je suppose) ???
    on t'avait bien dit pourtant de ne pas profiter de ton déplacement pro au pakistan pour faire des achats
    « Réponse #10 le: lun. 20 octobre 2014, 20:43:55 pm »
  • je bosse pas mal avec les roulements en conception de machines spéciales. Il faut absolument prendre des marques renommées comme SKF et FAG (entre autres). On calcule toujours la durée de vie des roulements avant de concevoir un montage. Et on arrive à des durée de vie en millions d'heures (sérieux). Il n'a a donc que trois possibilités à une avarie : roulements de piètre qualité, montage foireux et pièces porteuses (alésages et arbres) aux tolérances dimensionnelles et géométriques foireuses. Avec du Fiat italien (500 et 126 A), pas trop de risque. Avec la refab polak ou slovène... Où l'on voit que la faute ne porte pas que sur les roulements...  #g2
    « Réponse #11 le: lun. 20 octobre 2014, 21:24:44 pm »
  • Merci Lapin! Oui effectivement c'est dans un sachet bleu sans marque....je me souviens plus ou le les ai pris ceux la! .....mon Oncle me dit qu'on peut acheter le joint seul! si jamais vous avez un bon lien je veux bien! sinon au pire j'irai voir chez AD!  #g2
    ba pour 10 000 Laguignole achetés a 100€, deux roulements offerts! je ne pouvais pas rater l'occase!  #g6
